Version 6.6 (729) now Sun window can not be shown
Updated to Version 6.6 (729),now Sun Window (that connects with https://www.hamqsl.com/solar101sc.php?back=transparent) is not shown
73's Juan, EA5XQ
http://www.ea5xq.net
Re: Version 6.6 (729) now Sun window can not be shown
Works fine here.
Anything special to bring it up?
73's Juan, EA5XQ
I have installed 6.4.1 from here https://www.dl2rum.de/rumsoft/RUMLog.html and now it works fine Sun Window
73's Juan, EA5XQ
Which macOS version do you use? Maybe there is a relationship to this: viewtopic.php?t=2089 ?
My MacOs is Sonoma 14.8.9, but so far it has been working fine
73's Juan, EA5XQ
I was able to reproduce this problem on an older machine. The problem probably only appears when using the latest Xcode version with the latest SDK. I found a work around (hopefully). Please check: https://dl2rum.de/RUMlogNG/RUMlogNG.zip (Version 6.6.1 (730))
When you can confirm the fix, I will release it in the app store.
Hi, just tested and it works fine
73's Juan, EA5XQ
