I have been trying to solve a problem with LoTW Incoming, but I have now reached the point where I believe it may be a bug or an incompatibility.
Environment
- RUMlogNG 6.5 (724), Mac App Store version
- macOS Sequoia 15.4.1
- TQSL installed in /Applications
LoTW upload works perfectly, but LoTW Incoming always fails.
When I select QSL → LoTW Incoming → Load data from ARRL, the embedded LoTW login page is displayed.
Even after entering the correct LoTW username and password, it always reports:
Username/password incorrect
followed by:
Error while downloading data
What I have already verified
- I can log into the LoTW website successfully with Safari using exactly the same username and password.
- My LoTW password contains only letters and numbers (no special characters).
- Uploading new QSOs from RUMlogNG works correctly.
- I can manually download lotwreport.adi from the LoTW website.
- The downloaded ADIF contains 8 confirmed QSOs.
- The corresponding QSOs already exist in my RUMlogNG database with identical date, time, callsign, band and mode.
- I tested both RUMlogNG 5.19.5 and 6.5 (724); the behavior is identical.
- "Last LoTW QSL" remains at 12 Feb 1982 and is never updated.
Is this a known issue, or is there anything else I should check?
Thank you very much for your help.
Toru Mori
JG2TKH / JK1AKC
