Logging Window size not remembered.
va3cp
Unread post by va3cp »
When I start RumlogNG, the main logging window seems to default to full screen. I have to make it smaller every time I start RunlogNG v5.19.5
Running macOS Sequoia 15.7.2
27" 2020 Intel Imac.
Rumlog is running on a 24" second screen in 1080p mode
73, Dave, VA3CP
va3cp
Re: Logging Window size not remembered.
Anyone else having the same experience?
73, Dave, VA3CP
Run this command in the Terminal, it may help: defaults delete de.dl2rum.RUMlogNG "NSWindow Frame WinMain"
va3cp
Ran the command as suggested, rebooted the iMac and all is good.
Thanks for your help.
73, Dave, VA3CP
