CI-V CAT Command for IC-705
F5HFZ
Post by F5HFZ »
Hi
I am working to control my ic-705 by RUMlog. Not problem and very easy to connect by USB or Icom server. The UI is perfect and very fine.
I added some macros with the concatenation of CI-V commands (ie mode+pwr+filter+Pbt with one click)
But I can’t find the command to transmit the keyer memory. The notice from icom is not very clear.
The command 1A 02 is only to write/read the content of the memory
The command 28 00 is to transmit the voice memory. (For the Ic-7300 it seems working also for CW but I had no success with the 705).
Any ideas ?
(For now I am using the RUMlog CW memories)
My best 73
Nicolas,F5HFZ
Re: CI-V CAT Command for IC-705
Post by DL2RUM »
There is no command for that.
F5HFZ
Post by F5HFZ »
Many thanks Tom.
Nicolas
