Support for NanoVNA-H 4 HW V 4.2
A macOS companion application for FA-VA 5 and NanoVNA
VE3AJ
Post by VE3AJ »
Tom
Using a
NanoVNA-H 4
Hardware version 4.2
DisLord firmware Version 1.2.46 https://github.com/DiSlord/NanoVNA-D
Connects and reports version populates Band Stimulus window.
Further info after more testing.
I have created some bad calibration files I would like to delete
Unable to select them, menu grayed out
Cannot find them to delete manually. Looked in application support, searched in hidden folder/files
MacOS 15.6.1 (24G90)
Mac mini M4 Pro
Jim
Re: Support for NanoVNA-H 4 HW V 4.2
Post by DL2RUM »
Can you select the calibration from the popup in the Stimulus panel?
VE3AJ
Post by VE3AJ »
Yes
I can select a calibration file in the popup of the Stimulus panel
Delete selected calibration file remains grey in File Menu
Also
It will allow calibration files of the same name without warnings.
JIm
VE3AJ / VE7KAJ
Post by DL2RUM »
Okay, found it.
I will add a warning.
When you was able to calibrate, does this means all measurements are working? Your feedback is not very clear. Calibration is an option. It is not required since the NanoVNA gives us already calibrated data.
The 2.8" NanoVNA-H is limited to 1500 MHz and it is fixed to 101 scan points. I guess we need a feature so the user can change the limits.
