Activity Map max zoom out is still very small
vk1kcm
Unread post by vk1kcm »
Rumlogng is excellent and I greatly appreciate your work. One question, selecting "window->activity log->my qsos" brings up a nice map showing pins and paths from contacts in the log, however at its max zoom, it still shows only about half the planet. Is this the best it can do? Is it an Apple Maps limitation? See the attached screenshot.
Thanks!
Carl,
vk1kcm.
Re: Activity Map max zoom out is still very small
It's by design, see Apples Map application. It's the same 'problem'.
You could select another map type to see the globe.
