DX Spots ALL not sorted by last received
Although DX Spots Windows shows individually (per band) sorted by last DX received, ALL tab do not. I remember that previously it did it. Which is the criteria to be shown in ALL tab?
73's Juan, EA5XQ
http://www.ea5xq.net
Re: DX Spots ALL not sorted by last received
Just an example
3B9DJ arrived 3' ago, FK8IK in 17m 30' ago and when watch ALL see what happens
it is like some old spots remain at top as they would be spotted right now but it was half an hour before
73's Juan, EA5XQ
You have sorted the All table by dx de.
May be that picture was sent by mistake, look at these ones, are not sorted by DX and the first spots are older if you go to the specific band,
I do not know whether the problem comes from the DX CLuster, I do not know how ALL collect the spots
73's Juan, EA5XQ
Closed, I found the problem (I think)
73's Juan, EA5XQ
It would be helpful for others, when you share your experience.
Yes, you're right, apologies although I am not sure whether it is fine
In DxSpots I was not able to show the column FOR in order to order the spots by time , although I selected it it did not appear. I had to delete most of the columns and add FOR one and include new ones so now I am able to control the arrival of the spots
I will check it out later on to be sure that it solved the problem
73's Juan, EA5XQ
