cannot print qsl labels QL 700
Jacques
Re: cannot print qsl labels QL 700
Unread post by Jacques »
Hello made some progress .
given up trying to print labels to QL700 so tried to HP A4 printer . did save as PDF and it shows one good . did qsl out to print and printed see attachement) but always comes out on bottom as in photo
selected a few qso but only one come out ? how to select multiple QSOs if its to click hold down and select tried that but only first qso prints ?
sorry to be a nuisance but I am sure this is working for all so I must be missing something
Thank you
tesst print 1 card.pdf
(25.83 KiB) Downloaded 232 times
Best 73s Jacques F1VEV
When you still have selected the Dymo 29x90 label, this result is expected. Due to the nature of a label printer just one label is on one page.
Jacques
Crazy had forgotten the main setting so all now ok Thank you . Now I have to fine tune it before I buy labels etc . However I am getting on some QSO
To: XY1ZER via eqsl LoTW etc seems to come from the manager column how to remove that Cheers
Jacques
testing is going fine but now some qso have qsl via or some other information which is not wanted, so how to remove this I.e. what is in yellow in snapshot
thank you `
