WSJTX 2.7 and NG set up
Jacques
Unread post by Jacques »
still trying to get away from windows I downloaded WSJTX to my MacBook Air M2 but cannot get it to open let alone work ? so I must have missed a step ? Any "How to" information would be welcomed
73s Jacques F1VEV
Re: WSJTX 2.7 and NG set up
Read the attached file in the download.
Jacques
Thank I did many times did all the scripts plist etc and teh check returned shmmax shown as 52428800 so in theory good .
yet when click to launch I get place in BIN
? at a loss Cheers
Best 73s Jacques F1VEV
Jacques
after consulting an IT pro I had to do some modes to security on my Mac NOT an obvious thing to do various posts can be deleted Thank you
K7CAN
Unread post by K7CAN »
Did you get it setup? I have setup WSJTX on several Macs?
Jacques
Yes Thank you and all working well best 73s
Jacques
I have a question out on forum but maybe you can help I am trying to get QSO utility to read the log and upload to orz. com and HRDlog . net with no success .
If you have this worked out I would appreciate some input
I have qso utile all set up with passwords etc and UDP to listen to N1MM on 12060
in RL I have setting App info ticked with my local host and port 12060. as well listen to other instance ticked ?
obvioulsy I am not understanding something
Cheers Jacques
Jacques
just an FYI I got the qso utility work as it should Cheers
