Remote CW Sidetone for RUMlogNG CW contesting on Flexradio Transceivers
Carl
Unread post by Carl »
Hi all,
The question of “How do I get CW sidetone when I use contest software remotely on a Flexradio?” comes up fairly often for those with Flex transceivers. The issue is that FlexRadio provides sidetone for CW via a headphone jack on the rig itself or will do so through its Maestro remote console (that will be $1600 please), but otherwise, you have to cobble together some sort of solution yourself, usually requiring the addition of an external WinKeyer or other standalone hardware that itself generates sidetone.
This solution is for those hams who:
* Operate ham radio on a Macintosh.
* Own a 6xxx series Flexradio transceiver. I believe this should work with pretty much any radio in the 6000 series, but I haven’t tested it with anything other than my 6600.
* Operate your Flexradio using SmartSDR for Mac and you’d like to do it remotely (i.e., not sitting next to the transceiver but rather operating from a Mac elsewhere on the internet)
* Want to operate in CW contests using the excellent RUMlogNG software by DL2RUM.
If this is of interest, I've written a detailed description of how to configure RUMlogNG and SmartSDR for Mac so that you can get local CW sidetone when using RUMlogNG in CW contests. Please note that this solution does not deal with connecting an iambic keyer to the mix, but the documentation for SmartSDR for Mac has instructions for doing that as well.
You can read the post at:
https://www.wg1v.org/posts/2024-02-19%2 ... -RUMlogNG/
I hope this is helpful to others who may encounter this challenge.
Carl, WG1V
KD9ZHF
Re: Remote CW Sidetone for RUMlogNG CW contesting on Flexradio Transceivers
Unread post by KD9ZHF »
I appreciate your workaround. I did spend money on the Maestro - not a mistake, but certain wouldn’t do it again - it’s nice to know there are more options. I found another option - the Halikey by Hallibut electronics. It’s a small little connector for SMARTSDR - I use that and it works whether I’m using RumLogNG or not. it allows for use of a key from your Mac, iPad, and iPhone. It also can be used for a PTT switch.
Your workaround is interesting as well.
73. JS
KD9ZHF
