Info copied among Logs
ea5xq
Unread post by ea5xq »
I am using the main log for my callsign EA5XQ and also I have created one additional for each operation out of my QTH (EA2/EA5XQ, W9/EA5XQ,...)
I use 4 user fields: Rig_Condx, Propa_Condx, MyPwr and CW Keyer which I have marked for being copied in each QSO.
I have observed that when I create a new Log (for instance PA/EA5XQ) the values that I have used in the main log EA5XQ are shown too in the new Log PA/EA5XQ. I would expect that both Logs would be independent. what am I doing wrong?
Any comment will be appreciated
73's Juan, EA5XQ
http://www.ea5xq.net
Re: Info copied among Logs
I can't confirm this observation. When I create a new log, all user fields are cleared with no defaults.
ea5xq
Situation:
- Created all the logs in the same directory, User field names are different, changing the log it keeps their respective names, no problem
- If I mark “Remember” and I inform the user fields with log1, when opening log2 it keeps the values provided to log1
- Moved log2 to its own directory, it does the same.
In some way it stores the user fields values somewhere that new logs used them.
73's Juan, EA5XQ
Are you talking about your own presets in the combobox popup menu?
Then you are right. These values are stored locally. It could be make more sense to save it in the logbook file.
