RUMlogNG and N1MM+
PE2V
RUMlogNG and N1MM+
Unread post by PE2V »
Thanks for reading. It is asked before I'm afraid but I can't find the solution. What I want is simple but can't get it to work.
Case: I want to participate a contest that is only present in N1MM+ logger. I run the ICOM IC7300 and RUMlogNG on my iMac. I can participate the contest with N1MM+ of course but the frequency information from the 7300 is not present. So I tried several settings in the UDP settings but it won't work. Logging directly into RUMlogNG is not necessary, I can import a adif afterwards into RUMlogNG but the frequency, band and mode would be great.
Can someone please give me the network settings for RUMlogNG and N1MM+? The IP's:
iMac (Catalina): 192.168.1.173
LAptop (win10): 192.168.1.235
Please see attachments below for what I tried. RADIO with the laptop IP address and PORT.
But what should I do in the N1MM+ settings?
I really hope someone can help me with the settings.
tnx fer hlp es vy 73 :) Vincent de PE2V
Re: RUMlogNG and N1MM+
RL can send out radio information, I don't know if N1MM can use it.
RUMlog can control the connected radio, you have to connect as Dx-Lab-Suite-Commander client. I don't know if N1MM can do this.
I don't understand your intentions. When you don't want to use RL, connect N1MM to the radio.
PE2V
Ok, thanks.
