API
EI2KK
API
Unread post by EI2KK »
Hi
Is there any API (UDP?) I could use to send/change frequency and set value to callsign field?
Re: API
You can use:
  • Apple Script - see Function Library
  • UDP in the Flex Radio export format (N1MM Import)
  • UDP in the N1MM export format
EI2KK
Re: API
Thank you
