List of supported contests
hanz
Unread post by hanz »
Multipliers (count
only for valid QSOs) The last character of the worked station suffix (letter A-Z, digit 0-9) once per band and mode.
No need to indicate the multipliers in your log; the evaluation software does it automatically.
Upps, my fault. I will put it on my to do list.
hanz
Hello Tom,
Many thanks.
Alles gute.
73 hanz
PE2V
Unread post by PE2V »
I would like to participate the NTC QP (The NTC QSO Party). Is it possible to import the N1MM udc file? Or can this contest be added to RUmlog?
contest: https://pi4ntc.nl/ntcqp/
udc n1mm file: https://n1mmwp.hamdocs.com/mmfiles/ntc_qp-udc/
Maybe there is a similar contest I can use? Looked but don't know which to use. And I never used n1mm ....
tnx ! Vincent PE2V
M0LEP
Unread post by M0LEP »
RSGB VHF Christmas Cumulative contests do the VHF point-per-kilometre scoring with both DXCC and "Big Square" multipliers. Any other similar contests that could be used?
(Ref: https://www.rsgbcc.org/cgi-bin/contest_ ... t=xmasfun1 (and fun2, fun3 and fun4) and https://www.rsgbcc.org/cgi-bin/mults.pl ... 23&mult=M4)
Rick M0LEP
hanz
DL2RUM wrote: ↑Mon 4. Dec 2023, 17:41 Upps, my fault. I will put it on my to do list.
Many thanks for adding the OK memorial contest.
Great.
HNY
hanz YL3JD
iz6fxs
Unread post by iz6fxs »
Please add the CQBBI contest from the Mediterraneo DX Club:
https://www-mdxc-org.translate.goog/cqb ... r_pto=wapp
I'll be happy to assist since the rules are only in Italian.
Thanks!
Norm IZ6FXS
PE2V
PE2V wrote: ↑Thu 21. Dec 2023, 10:59 Hello,
tnx ! Vincent PE2V
I used the 'General Contest' for this and works fine! Thanks for this option!
es7agw
Unread post by es7agw »
Hi!
Would it be possible to add Estonian HF cup (ES LL KV)
Rules are here in Estonian:
https://erau.ee/images/LL/ES%20LL%20KV%20reeglid.pdf
Short translatation:
Categories:
mode category: MIX, CW, SSB
power category: 100w or 10w (QRP)
if it is clubstation or not
if it is junior operator or not
Contest time:
- Usually every first Saturday (except june, july, august)
- from 10:00 - 10:59 Eastern Europe Time (winter +02:00/summer +03:00)
- There are 3 periods:
1. periood: 10:00-10:19
2. periood: 10:20-10:39
3. periood: 10:40-10:59
- Every period same station can be contacted once in CW and once in SSB.
Suggested freq: 3530-3560 kHz CW, 3600-3650 kHz SSB.
Exchange: RS(T) + serial No, starting 001 (number is continuous).
Points: Each CW QSO gives 2 points, each SSB QSO 1 point.
Total score: Sum of QSO points
Thanks, Priit
Please use the General contest template for minor regional contests.
