end time same as start time
hanz
Unread post by hanz »
Dr Tom,
Noticed today, when i add a call in the callsign box and i press tab and go back to the call sign box or by mouse or shift tab and i save the qso end and start time are the same.
Does it mean i should nver save a qso while the cursor is in the callsign box?
attached a video
hanz YL3JD
8F5D4FDD-5B93-4E6A-B79B-7E14676F88E1.mov
(4.75 MiB) Downloaded 376 times
Re: end time same as start time
You gave the correct answer.
The QSO start time resets always, when you leave the callsign field. During saving a QSO, the callsign field becomes inactive and this triggers the change of the QSO start time.
hanz
DL2RUM wrote: ↑Thu 10. Aug 2023, 18:41 You gave the correct answer.
Hello Tom,
Thanks for the always quick reply.
Thanks for confirming.
Have a great weekend.
73 hanz
