Log missing
EA2CIN
Log missing
Unread post by EA2CIN »
Good afternoon:
This morning I have installed a certificate from the Administration of Spain and I have lost the log. It is a mystery that Time Machine has saved copies after that time (empty in the log) but the above dates back to March. Can I somehow recover the data?
Thank you
Albert
EA2CIN
f5ukw
Re: Log missing
Unread post by f5ukw »
EA2CIN wrote: ↑Sat 22. Jul 2023, 15:28 Good afternoon:
Thank you
Albert
EA2CIN
Did you tried to fetch your old rlog files from your TimeMachine's folder? It's odd than installing new certificate would make any change in your log, I assume you changed your user session. But unless you specifically asked time Machine to not backup your working folder where RUMlogNG save log, you should be able to get access to them
