Xiegu G90 settings
pippoiu2qcy
Xiegu G90 settings
Unread post by pippoiu2qcy »
Hello, I would like to configure Rumlog to work with Xiegu G90. Is it possible?
I just installed FTDI D2XX driver, Usb port sees "serial".
In Rumlog preferences i can't find manufacturer and model, there is a way to configure manually?
Thanks a lot
73 de IU2QCY
DL1BZ
Re: Xiegu G90 settings
Unread post by DL1BZ »
Use ICOM IC-7000 19200Bd 8N1, CIV-address 0x70 or 0x88. Works for a long time for me.
73 Heiko, DL1BZ
ICOM IC-705, YAESU FT-710, FX4-CR/ Macbook Air M1 running macOS 13.6 RUMlogNG / JTDX / fldigi / Black Cat SSTV
pippoiu2qcy
DL1BZ wrote: ↑Tue 30. May 2023, 18:25 Use ICOM IC-7000 19200Bd 8N1, CIV-address 0x70 or 0x88. Works for a long time for me.
73 Heiko, DL1BZ
Thank you Heiko, can you indicate me where i have to put "8N1" and CIV-address please? I can't find these field.
73 Pippo IU2QCY
