Contest set-up and use...
M0LEP
Unread post by M0LEP »
I've been using RUMlogNG for a while to capture logs from WSJT-X, and it's been doing that just fine, talking both to WSJT-X and to my IC-7300.
At the beginning of last month I started a CWOps CW course. My instructor is keen to get us to participate in a couple of contests, the CWOps Mini Contests (CWT) mid-week, and the K1USN Slow Speed Test (SST) on Friday evenings. All the course instructions for contest participation assume we'll be running N1MM :roll: and I've never done any contests before :o so they're something of a black art :twisted:. The closest I've got is using Morse Runner for training exercises. :roll:
I've noticed that both those contests are in RUMlogNG's list, and I've tried to follow the instructions under https://dl2rum.de/RUMlogNG/docs/en/pages/Contest.html to get it set up for them, but I can't figure out what needs to go into the Contest Preferencss CW F-keys, and I've not managed to find examples anywhere. Both contests (as far as I can tell) have un-changing exchanges (without RST or serial number). I think they should contain something like this:
F1: CQ CWT <My Call>
F2: <His Call> RICK CWA
F3: TU 73
F4: <My Call>
F5: <His Call>
F6: <His Call> RICK CWA
F7: ?
F8: ?
...and for SST (in which I stand half a chance of maybe catching a caller or two, possibly), replace CWT with SST and CWA with DX.
Is that anywhere close to what's needed? I've experimented (with rig at zero power into a dummy load), and while the rig keys sometimes, there's something I'm not getting quite right (though I'm trying to follow the flows on https://dl2rum.de/RUMlogNG/docs/en/pages/InContest.html ) as it doesn't always key as expected or create a log entry.
Rick M0LEP
ct1drb
Re: Contest set-up and use...
Unread post by ct1drb »
Hi Rick,
how are you doing?
Name is David, calls are ct1drb and ok8rb and my qth is close to Lisbon.
Cool that you are learning CW. As a almost 100% CW operator I am very happy with it.
At same time it seems that you have problems with RUMlogNG and configuration with the CWOps settings.
If you want I can give help but I would like to have a king of a Skype session where we can talk and later one try to solve your problem.
So, if you have Skype let me know and then we can arrange a schedule to help you, my ID Skype is ct1drb.
Best 73 and have a nice week.
CT1DRB/OK8RB
David Quental
M0LEP
Thanks. I think I've mostly worked it out, at least for S&P mode. The mistakes I made were, first, mis-understanding the blue button that suggested (to me) that I needed to click it to perform the next action, and second, using F6 to send the S&P response and then not being able to get the entry into the log. There are clearly more tricks to learn, and I am slightly hampered by having a small keyboard that doesn't have distinct return and enter keys. I'll get there...
Rick M0LEP
IU3BRO
Unread post by IU3BRO »
What I cannot find in the Help, which is at least poor, is the name to give to the various variables, e.g. in other logger, {MYCALL} or @MYCALL or similar.
Somebody can please answer? Maybe the author of the software?
73 Tilio iu3bro
It's just in the CW settings:
