IC-7610-Control Window "Change" Button
K6CES
Unread post by K6CES »
I am embarrassed asking this question. Maybe I have not had enough coffee.
Is the 'Change' button that appears on the IC-7610 below the 'Main/Sub' button duplicated on the IC-7610-CTRL window? I would like to swap the Main and Sub receiver so that 'Without Wire' will work with the frequency that was on the sub-receiver.
Chuck, K6CES
Re: IC-7610-Control Window "Change" Button
Try the Main <-> Sub button in the VFO section.
K6CES
Sigh. I was looking right at that. I do not know why I thought that made both receivers the same frequency.
Thank you Tom.
73, K6CES
Therefore we have the Main --> Sub button.
