Cannot upload November Sweepstakes Cabrillo file
K0NOC
Unread post by K0NOC »
Hi, I used the Contest window for the phone 2021 ARRL November Sweepstakes this past weekend. I exported my QSO's via the Contest > Export to cabrillo menu. Then I loaded the file to the ARRL online log files submission page. I got this error...
Is this a problem with RumLogNg or did I somehow enter my data incorrectly? Here's what my QSO's look like in the Contest window...
Thanks much for your help! :D
Re: Cannot upload November Sweepstakes Cabrillo file
There are missing spaces in your sent control number.
050 A21MN should be 05 A 21 MN In the number received it looks correct.
Furthermore you should check your frequency settings for your 40m band in the preferences.
K0NOC
Thanks much! I'll get to that editing.
On the 40m band thing. I noted...well, a couple of things in the Contest app.
1. The 40m band setting did not hold, if I updated the frequency. After updating the frequency it went blank and I had to re-select it each time (missed a couple). Whereas I did not have that problem with the 20m band. Please check this for a bug.
2. The 40m band frequency field did not save properly to the QSO record. There were a lot of them that just saved down as 7,000 even though I had input a specific frequency. Is that a bug?
Also, there doesn't appear to be a way to edit the frequency once saved down to the grid. :(
Thanks.
