Hello Thomas,
I noticed this a long time ago but didn't think about letting you know. When I go into the top menu and select Grid squares from the Window menu RUMlogNG closes / crashed or whatever the reason is why it is shutting down... I can't say from when it stops working... sorry.. a long time ago it works fine (never used it a lot).
I'll try to add the crash report, I hope this helps.
Vy73 Vincent PE2V
Crash Window/Grid squares
- Attachments
- crash-RUMlogNG-Grid-squares.txt
- (98.41 KiB) Downloaded 390 times
crash-RUMlogNG-Grid-squares.txt- (98.41 KiB) Downloaded 390 times
Re: Crash Window/Grid squares
I have an idea. There may be QSOs in your log with an invalid Band info.
Please try this version and report back: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
Good morning, that did it! Looks good now!
Thanks!!
Vy73 Vincent PE2V
Thanks!!
Vy73 Vincent PE2V
