Colour scheme
g0vgs
Colour scheme
Unread post by g0vgs »
Any chance of a Blue theme Tom?
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: Colour scheme
:?: :?: :?: :?: More details please... :!: :!: :!: :!:
g0vgs
Re: Colour scheme
Well, like the green theme now only blue :) I guess most Mac users use blue as their default and RumLOG is green. Shades of blue would be nice to have. Either that or the option to change colours manually using palettes?
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: Colour scheme
Oh, well. A customizable color scheme is planed for one of the next major updates.
Re: Colour scheme
You can test a first Beta to create your own colours. Put the downloaded files into your existing RUMlog folder.
To change the colours go to Menu-->Window-->Colour Schemes
Use the "Save As" button to save your colour schemes into the "Colours" folder within the RUMlog folder. Using the popup menu, you can reload these schemes.
Feel free to upload your screen shots and the colour scheme files.
http://dl2rum.de/rumsoft/RUMlogToTest.zip
Schemes.tiff
Schemes.tiff (73.85 KiB) Viewed 14157 times
Schemes.tiff
DG5MMQ
Re: Colour scheme
Unread post by DG5MMQ »
where to load up the colour scheme?
mmq-scheme
mmq-scheme
Re: Colour scheme
Great colours !
Post the colour file here in this thread as attachment. It's just a text file. Maybe you have to add a txt or xml extension.
Later on I will distribute the colourschemes within the download.
g0vgs
Re: Colour scheme
A great start Tom :) Many thanks. I guess there are a few more things needed. Text colour for example. The band scale in the band map and the header line in the log, drop downs etc if possible.
Many many thanks for a great program :)
I will post a couple of schemes soon.
73 Ian
Ian J Maude | G0VGS
K3s #10268
g0vgs
Re: Colour scheme
Here is the first one.
73 Ian
Ian J Maude | G0VGS
K3s #10268
g0vgs
Re: Colour scheme
Hopefully this should be the scheme! I have renamed it with a zip extension which was the only way to post it I could find. Just remove the .zip to use (hopefully)
73 Ian
GreyBlue.zip
(953 Bytes) Downloaded 675 times
GreyBlue.zip
Ian J Maude | G0VGS
K3s #10268
