Default windows on startup?
BMWrider
Unread post by BMWrider »
Is there any way to set the default windows that open on start-up? For example, the Network status window automatically opens when I start RumlogNG. I don't need this window and would prefer it not automatically open. There same goes for the IC-7300 radio window. I'd prefer to only have the main logging window open when I start RumlogNG and then select any other windows I'm interested in as needed.
KF0ADW | Bruce F.
Re: Default windows on startup?
Nearly all windows remember the state. You are right, this option is not available for the Network window. It should popup only, when you have configured a network function.
If you don't like to see the TRX Control window, deselect the Ctrl option in the TRX setting.
