Avery 3474 labels cut off on the top
ea7tb
Re: Avery 3474 labels cut off on the top
Unread post by ea7tb »
Hello.
Happens to me something.
Do not use the AVERY 3474, but a generic of 70x37 (24 labels per A4) 5staroffice brand, model 903814. No top margin or lateral margins.
The printout is shifted down and to the right.
Not printing the last three labels.
To see how to print, I have attached a picture of the page, with pen marking the separation of the labels.
My printer is a Brother HL-2035
As could be solved?
Regards.
Manuel EA7TB
Manuel EA7TB. 73'
ddanecki
Unread post by ddanecki »
¡Hola Manuel!
This is because you have not set up the correct paper size before printing.
  1. RUMlog Menu-->Edit-->Page Setup-->Manage Custom Sizes...
  2. Click + sign and call your paper size somehow "RUMlog" or something else
  3. Set paper size to: width 210mm, height: 297mm
  4. Set all margins to: 0mm
  5. Click OK
  6. in Paper size field, choose your newly created paper size
  7. Quit RUMlogNG and run it again.
  8. Try to print now
Let me know what is the outcome. If you will have problem with 3 first labels cut off from the top, I'll tell you how to bypass that.
de SQ2KLU
Daniel
SV1QFV
Unread post by SV1QFV »
I am reviving this thread. The case here is the following: I don't own a printer so i print to pdf and then i want to use this pdf to print the labels on our office printer.
I have already applied the no margin trick as described above but when i will try to print the pdf the printer it cuts the top and bottom
According to printer specs
Maximum printing area:
Print margins: Top: 4.23 mm; Bottom: 4.23 mm; Left: 4.23 mm; Right: 4.23 mm;
Maximum print area: 211.8 x 351.8 mm
Is any other workaround ? Or an easy way to create my own custom template ?
73 SV1QFV
When your pdf looks correct, you have to adjust the printer settings in the office too.
SV1QFV
Thanks for the reply.
The PDF looks correct, according to a measurement with FoxiT Reader the TO STATION is exactly 2.54mm from the TOP of the page (with set all margins to: 0mm)
Is there a way to create a new label template with a different TOP margin (if that thing exists) ? (like 5mm ?)
When your printer can't use the full labe size, you should consider to use another label format. See Avery 4738 (or others), here is a print free area on all sides.
SV1QFV
Thank you Tom appreciated
