ADIF File
N1JM
ADIF File
Unread post by N1JM »
When I export an ADIF file, the time in the file says off time. That presents a problem when importing to DXLabs. DxLabs wants to see an on time.
My main logging program is RumlogNG but when I use a PC, I like to keep DXLabs DXKeeper up to date with RumlogNG.
73, John N1JM
Re: ADIF File
See the pop up menu below the date- and time field in the logging window. Select QSO start time and export your QSOs again. There is no rule in the ADIF specification which time to use.
N1JM
Re: ADIF File
Thanks, Tom. That cured it.
73, John N1JM
