labels print oriented wrong, up and sown instead of left to right. i did read the manual.
Ray
W8LYJ
QSL Labels with Demo 450 Label Printer
Re: QSL Labels with Demo 450 Label Printer
You have to create and select the correct sheet of paper.
Found problem, print set up, label width is actually label height, height is length. Reversed my numbers and all is well sort of, first line,” ..glad to confirm....” type is too small. Anyway to increase size? What controls type size.
Ray
W8LYJ
Ray
W8LYJ
Direction is now correct, created new label, 1.8 x 3.4. How is the text moved down the label? losing part of top line.
Ray
W8LYJ
Ray
W8LYJ
Maybe it makes more sense just to change the orientation from portrait to landscape?
Make sure you paper has set all borders to 0.0.
