QRZ lookup, show path?
PG4I
Unread post by PG4I »
Howdy folks, happy newyear!
I have started using RUMlog2Go on my ipad on january first. I have entered my QRZ.com credentials in the log setting, triple tapping the QSO looks up the call correctly in a new screen. There is a button called “show path” but I never see a correct line. Sometimes there is no line, sometimes there is one but it poins into the atlantic ocean west of africa (south of Togo actually). Is this a bug?
So far very happy with the logger, thanks!
Re: QRZ lookup, show path?
Do you have payed for the qrz.com logbook xml subscription?
PG4I
No sir, do I need to?
Yes Sir!
Or you could use HamQTH.com.
PG4I
Thanks for the tip Tom, will try it out.
Regards,
Joop
PG4I
Awwww, that is much better! Thanks!
sndtubes
Unread post by sndtubes »
When I try HamQTH.com I get Error Parsing XML URL Not supported?
Try to use a password without any special characters.
