Maps?
DougY
Maps?
Unread post by DougY »
Are there any plans to include APPLE MAPS in the current version?
If not, how can I download and install a previous version?
Re: Maps?
A map is available in the HamQTH/qrz.com window and a separate map from the Window menu. Why do you ask for an older version? RUMlogNG used always Apple Maps as source.
DougY
Re: Maps?
DL2RUM wrote:A map is available in the HamQTH/qrz.com window and a separate map from the Window menu. Why do you ask for an older version? RUMlogNG used always Apple Maps as source.
When I log a QSO into RUMlogNG, the HamQTH Map no longer shows. Im sure its something in my configuration thats wrong. And I still have not been able to get the program to communicate with my Yaesu FT DX 1200.
Re: Maps?
Is just the map missing or the whole window? A screen shot would be helpful.
DougY
Re: Maps?
Just the map is missing. When I had RUMlogNG running with my Icom 746Pro, everything worked perfectly.....now that I have a Yaesu FT DX 1200, nothing works. No communication with my radio, no map. Ive been through the RUMlogNG configuration so many times...just cannot figure out what is wrong. When I want to log a QSO, I have to do it manually, and when I put in the Callsign, no map comes up. I have to manually input the date, time, etc.
Please see Screen Shots of my Preferences below....any suggestions would be helpful.
DougY
Re: Maps?
Re: Maps?
You haven’t selected a port for the serial CAT control port.
Re: Maps?
Just the map is missing? Do you see the HamQTH/qrz.com information?
DougY
Re: Maps?
DL2RUM wrote:You haven’t selected a port for the serial CAT control port.
All the dropdown menu offers is a Bluetooth Incoming Port or Not Used
DougY
Re: Maps?
DL2RUM wrote:Just the map is missing? Do you see the HamQTH/qrz.com information?
The HamQTH information does not show after I type in the Callsign. I have to put it in manually.
Ive already checked the HamQTH.com site, and I am registered.
RUMlogNG identifies the Callsign Country of Origin, but no other information. And the Map doesnt show on the screen.
