RumLogNG Crashes soon after opening
Re: RumLogNG Crashes soon after opening
Okay It was not set but now I have set it to Auto Discovery.I did notice from time to time I would have to reset the IC-7610 comport but it never caused a crash before. Now that it is set I will see what happens.
Thanks, John N1JM
Thanks, John N1JM
Just went into preferences and then closed preferences and crash again.
- Attachments
- crash again.rtf
- (79.13 KiB) Downloaded 400 times
crash again.rtf- (79.13 KiB) Downloaded 400 times
The crashing seems to be associated with the IC-7610. I have taken the IC-7610 out of RomlogNG and it hasn't crashed yet. I have only the K3s now.
73, John N1JM
73, John N1JM
Well program has not crashed yet but will hang when going into preferences and this time when changing to a different tab. Have to force quit the program.
73, John N1JM
73, John N1JM
I have seen the hang now by myself.
It has something to do with the installed/connected sound cards. Even if you haven't configured any. I made few changes and haven't it seen it again. But I was not so much affected like you. There is at least one other user affected with the TRX problem. This I have never seen and I have still no idea.
Pse check this version for hangs: http://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
I just tried the new version from he Mac app store and the program crashed when exiting preferences.
73, John N1JM
73, John N1JM
Here it is.
- Attachments
- rlcrash101218.rtf
- (79.1 KiB) Downloaded 390 times
rlcrash101218.rtf- (79.1 KiB) Downloaded 390 times
