RumLogNG Crashes soon after opening
RumLogNG crashes within a couple minutes of opening. Just started. Using Version 4.0.2 (272), OS Ver. 10.14. Crash log is attached.
- Attachments
- crash_log.rtf
- Crash log
- (81.24 KiB) Downloaded 409 times
crash_log.rtf- Crash log
Re: RumLogNG Crashes soon after opening
Seems to be problem with one of the band map windows. Make sure these windows are closed or have a suitable size.
I looked at the maps and I don't think they were set to open. I ended doing a clean reinstall. That seems to have fixed the problem. Thanks.
Version 4.0.2 (273)
Getting beach ball still occasionally when going into preferences. Have to force quit. Also sometimes crashes. MacOS 10.14.
73, John N1JM
73, John N1JM
Please send me the crash report. It was reported, it is helpful to logout once after the update.
Just happened after exiting preferences.
- Attachments
- crashlog.rtf
- (82.04 KiB) Downloaded 439 times
crashlog.rtf- (82.04 KiB) Downloaded 439 times
What have you done in the Preferences? Do you have connected a trx? Which model and which port?
TX1 K3-Ctrl. port usbserial-A504TLUF
TX2 IC-7610-Ctrl. port SLAB_USBtoUART
Do you use the IC-7610 Auto Discovery Function?
If you mean CI_V USB Baud rate, it is set at 115200 not auto.
