second call sign
hanz
second call sign
Post by hanz »
Dear OM,
For several month a year we live in Latvia where i have my other callsign.(YL3JD)
Is it possible to log qso's in rumlog with a second callsign?
73's hanz de pa3zz
Re: second call sign
Post by DL2RUM »
When you are operating from different DXCC entities, you can't use the same logbook file.
hanz
Post by hanz »
DL2RUM wrote:When you are operating from different DXCC entities, you can't use the same logbook file.
That's the case, i work from diff entities.
73' hanz
DJ2RB
Post by DJ2RB »
In this case, you must install a new logfile fer the secand call.
vy 73 Rolf
hanz
Post by hanz »
DJ2RB wrote:In this case, you must install a new logfile fer the secand call.
vy 73 Rolf
Hi Rolf,
If i understand correct, you mean i have to run a second copy of Rumlog. Running seperatly from the other one?
An other question, can I add a new mode, FT8?
73's
hanz
Post by DL2RUM »
Hanz, you can't run multiple instances of RUMlog. You have to create a new Logbook file. See the Logbook menu.
hanz
Post by hanz »
DL2RUM wrote:Hanz, you can't run multiple instances of RUMlog. You have to create a new Logbook file. See the Logbook menu.
Thanks, works perfect.
73's hanz
hanz
Post by hanz »
Sorry to keep asking questions.
Is it possible to change the directory of the log files.
I have got two at the moment, never thought of having two and i want to place them on e specific place, also got to do with auto backup.
I tried several things l;ike crerating an empty log and copy the old one over it etc.. but taht doens't work.
Is there a way to do this?
Thanks for your patience.
73 hanz
Post by DL2RUM »
  • Quit RUMlog
  • Move the used file wherever you want
  • Restart RUMlog
  • Use the Menu-->Logbook-->Open Logbook to navigate to your file
The last step isn't required, when you use RUMlogNG, due to the Sandbox structure.
hanz
Post by hanz »
DL2RUM wrote:
  • Quit RUMlog
  • Restart RUMlog
Thanks thanks.
I know what went wrong here.
The main logging window wasn't openend and then open logbook is greyed out.
When the main log window is opened then open logbook is black and i can select the log file where ever i like.
I will not bother you again :-)
Have a nice weekend and thanks for the quick responses.
hanz 73's
