[Solved] Voice Keyer on TS-590S No audio
Hi all!
I am trying to use the Voice Keyer with my TS-590S. This is how i have set it up:
M4a audio file with my callsign in Library/Containers/de.dl2rum.RUMlogNG/Data/Documents/Voicekeyer_Recordings
In Preferences/Phone Memory F1 configured to use this file. File plays ok when sent to default audio device.
Audio device in this pref panel set to USB Audio CODEC.
Switch PTT selected.
CAT control is working correctly.
Radio is connected using USB.
In TX1 pref panel For PTT is set to TRX CAT.
Now, when i press F1, the radio goes in TX, but no audio is sent. My guess is that the radio is not listening to the USB port (TX1 command).
Any ideas how to make this work?
EA3HOE Ton.
EA3HOE Ton.
Funny how this board doesn't have the ability to delete your own account.
Re: Voice Keyer on TS-590S No audio
Maybe you have to configure your transceiver to accept voice audio from USB?
This has to be done through the TX command. The TX(0) command (default) sets the transceiver to TX and lets it listen on the mic port for audio and the TX1 command let the radio listen on the USB port for audio.DL2RUM wrote:Maybe you have to configure your transceiver to accept voice audio from USB?
Every program i have used in the past has a setting for the TS-590 where you can decide where the radio receives its audio. I am (almost) sure RumLogNG also has this setting, i just haven't found it (yet).
Ton.
No, I have to add this feature! Thanks for pointing out.
Thanks!!DL2RUM wrote:No, I have to add this feature! Thanks for pointing out.
Just checked, RUMlog applies "TX1;" over the CAT for PTT on.
According the manual for TX1;: DATA SEND (ACC2/ USB input)
Does this mean, it is used in DATA mode only?
In my case when I pressing F1 nothing happens.
Screenshot attached. Cant get working...
What i'm doing wrong?
Regards, Kes.
Regards, Kes.
It's works now, but only when going to menu CW / Memory 1 and pressing with a mouse...
When pressing on keyboard F1 nothing.
But actually sound goes on air.!!!!!!!
Kes, when F1 don't work, make sure the log window has the focus and you don't have assigned another function to the F keys in the system preferences.
Ye founded ...F1 used different app.
Thank you Tom!!!!
Thank you Tom!!!!
