RUMLogNG version 2.10
What's new?
  • Change: The Fldigi preferences can be found now under the µHAM/Fldigi tab, no changes in function
  • New: Support for QSL label Avery 8462 (1-1/3" x 4" at US-Letter 2 x 7)
  • New: IC-7300 control window - select IC-7300 Ctrl as transceiver
  • New: The eight CW memories for the IC-7300 can be edited --> Menu-->Transceiver-->Edit CW memory
  • New: You can set the serial CAT port flow control lines to High, to power up the interface
  • New: Option added to use a Bluetooth Low Energy Modul CAT interface
  • New: Provisions made to use the internal CW keyers in IC-7100, 7300, 7410, 7700, 7850, 7851 and 9100
  • New: DXCC search: option added to search for exclusively LoTW or paper confirmed entities
  • New: Command added to set the Paper QSO Status for selected QSOs to -: Menu-->QSL-->Do not send QSL. This works in the Search Windows as well.
  • New: RAC Canada Day Contest
  • New: Venezuelan Independence Contest
  • New: DL-DX RTTY Contest
  • New: IARU HF Championship
  • New: RSGB Low Power Contest
  • New: RSGB IOTA Contest
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:http://dl2rum.de/RUMlogNG/docs/en/
Win_7300_Ctrl.tiff
IC-7300 Control window
Win_7300_Ctrl.tiff (94.82 KiB) Viewed 7735 times
Win_7300_Edges.tiff
Scope fixed edge frequency editor
Win_7300_Edges.tiff (74.08 KiB) Viewed 7735 times
Win_7300_BSR.tiff
Band stacking register editor
Win_7300_BSR.tiff (68.03 KiB) Viewed 7735 times
Win_7300_Memories.tiff
Memory editor
Win_7300_Memories.tiff (136.02 KiB) Viewed 7735 times
Memory editor
Memory editor
n7xy
Re: RUMLogNG version 2.10
Unread post by n7xy »
I notice when using 2.10.1 in the IARU HF contest that it was correctly getting frequency and mode data from my KX2 in the main logging window but not when I switched to the contest window (it acted as if the radio was not connected). A CAT reset did not help. If I switched back to the main logging window the data was there again.
n7xy
Well I spoke too soon. It is now working as expected after turning the program back on after being off for an hour. ??
