Hello, I have bought RUMlogNG on the appstore and installed on iPadmini2, iOS8.3 (12F69) and iPhone 4s, iOS 8.3 (12F70).
On both devices the app does not start, it closes immediately after tapping the icon.
Do you have any suggestions to fix this? I would be glad if I could use your app.
Best regards,
Martin
RUMlogNG does not start
Re: RUMlogNG does not start
This may happen, when you are out of memory.
Otherwise, I'm not able to test under 8.3. Can you provide the crash log?
Thank you for the quick response, attached is the crashlog from my iPad.
73 de OE1MSW
73 de OE1MSW
- Attachments
- crashlog.txt
- (39.33 KiB) Downloaded 662 times
crashlog.txt- (39.33 KiB) Downloaded 662 times
Tnx,
this version can't work with iOS 8.3! My fault. I will release an updated version in few days. Thanks for pointing out.
