Winkeyer
NF4L
Winkeyer
Unread post by NF4L »
I'm trying to get Winkeyer (a kit I just finished) working with NG and an ICOM PRO II. The CW key window says there is no CW interface. Running on a MacBook Pro OS X 10.11, USB/serial adapter to the keyer. It works on Windows (Parallels) on the same machine and cable.
73, Mike NF4L
73, Mike NF4L
Re: Winkeyer
If you want to use the Winkeyer, you have to select it from the "CW Interface" pop up menu in the CW preferences.
NF4L
Re: Winkeyer
Thanks, Tom.
NG now recognizes the keyer, but still doesn't key the rig. Is there some other setting I'm missing?
73, Mike NF4L
73, Mike NF4L
Re: Winkeyer
You have to select at least one key output.
NF4L
Re: Winkeyer
Thanks Tom! Key out 1 did it.
73, Mike NF4L
73, Mike NF4L
