Hi.
I just upgraded wing version 2.4. When I run the program is not able to read the data file where preferences were, nor can open the log file gives the error: "The File Could not be opened"
Any suggestions to solve the problem?
Regards.
Manuel EA7TB
Problem with RUMlogNG 2.4
Re: Problem with RUMlogNG 2.4
- Start RUMlog
- Select Menu-->Logbook-->Open
- Navigate to your file
- Post a screen shot of the error message
Hi.
Just start the program exits the (RumlogNG_01) window.
Once the log file is selected, the screen is as follows (RumlogNG_02).
If I try to save a new contact, the next screen (RumlogNG_03) appears
Regards.
Manuel EA7TB
Regards.
Manuel EA7TB
- Attachments
- Rumlong_01.tiff (27.04 KiB) Viewed 7134 times
- Rumlong_02.tiff (131.94 KiB) Viewed 7134 times
- Rumlong_03.tiff (18.37 KiB) Viewed 7134 times
Manuel EA7TB. 73'
Could be an issue with the user permissions. Where is your log file located? Move it to the desktop or to the Documents folder and try again.
In the previous version it worked sim problems.
What is the directory where the file is saved preferences.?
He missed the preferences file and when complete again not saved.
The log data with this in a folder of documents.
The RUMloNG.app file is in the Applications folder.
Regards.
Manuel EA7TB
Regards.
Manuel EA7TB
Manuel EA7TB. 73'
Why do you think the preferences were not saved? Do you have tried to reboot your Mac?
Already resolved. In story I reset to operated without any problem .
Many thanks for your help.
Best regards.
Best regards.
Manuel EA7TB. 73'
