Missing DXCC & Cnt for TO4E and VP8SGP
W0DJC
Unread post by W0DJC »
I sorted my log by DXCC in the main logging window, and see that two calls, TO4E and VP8SGP have a problem. The DXCC column is blank for these calls, and the Cnt is showing (null). If I go into Window, then DXCC Entities and pull up my DXCC Table, the contacts for these stations show up in that table. By that I mean that for the bands and modes that I worked these stations on, the table correctly shows that I made those contacts.
I did a recalculate DXCC's for these contacts, but they still show up as blank for DXCC, and (null) for Cnt.
Should I just manually correct them one by one, or is there some other way of correcting this problem?
Thanks!
Don
Re: Missing DXCC & Cnt for TO4E and VP8SGP
  • Go to Menu-->Online-->Show DXCC Database
  • Go to the Exception tab
  • Enter the callsign in question into the Callsign search field
  • Check if the QSO date is in the given range
When it is okay just double click the QSO in question in the log table to bring it into the QSO Edit Mode. After pressing "Save", it should show the correct information.
You can't manually change the DXCC nor the continent.
W0DJC
All QSO's were in date range. Double clicking them and saving corrected them.
Thanks!
