I'm trying to use RUMlogNG to print Labels. I've got Avery 3437 labels (70x37). I have set up paper size to 210x297 with 0mm margins.
The problem is that first labels are cut off from the top. Approximately 2mm. When I try to set up 2mm margin on the top, every second page is blank (whatever is supposed to be on 1st page, does not fit there). I could probably live with that, however it would be much easier if I could get it to work as it should.
I understand that the printer has "non printable area" which cannot be printed and that's where the cut off is coming from.
Did you have a similar problem ? Or is it just me ? I've tried couple different printers, HP C3480, HP P2055, Konica Minolta C203 (this one was supposed to be able to do borderless print, but I couldn't get it to work).
Any word of wisdom will be appreciated
