from some days I have a problem with the function LoTW TQ8 Out ......
All this occurred after a forced shutdown of the PC for of a power line.
The error message is the image attached.
Some help ????
Database Error: Invalid Argument (LoTW upload) SOLVED
Re: Database Error: Invalid Argument (LoTW upload)
It's a tqsl error. What happens when you press "Ignore"?
Thanks for answering my question.
If I press Ignore in RUMlog apparently nothing happens, I tried directly from TQSL and what happens you can see in the attached image.
When I leave TQSL give me the error attached to the end.
You could enable the Diagnostic mode in the File menu. This may give you more detailed information about the problem. It seems one of the used databases in damaged.
In attached the file log produced in Diagnostic mode after select "Ignore".
- Attachments
- tqsldiag.log
- (73.2 KiB) Downloaded 1009 times
tqsldiag.log
do you have some news that can help me????
Dario
Dario
No, you should ask tqsl for support.
I would export my certificates and other settings, delete all files and would perform a clean install.
Re: Database Error: Invalid Argument (LoTW upload) SOLVED
in attach the solution.
It was a TQSL problem.
Dario
Dario
- Attachments
- Data Base Error rev 2014-5-23.pdf
- (61.75 KiB) Downloaded 1032 times
