Posts: 3106 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Sun 17. May 2015, 17:16
In the last time I have got very few bug reports. This new version brings more new features and advancements:
Fixed: DXCC computation for KG4 optimized - Tnx N1HO
Fixed: IOTA reference for Oceania can now be entered correct - Tnx IK2EAE
New: All areas currently located in the gray line can be listed in a separate table - See the link *Miscellaneous Windows*
New: Support for Dymo Labelwriter format 57mmx32mm - Tnx DL7XT
New: Extended QSO search
New: Support for FT-991 - Tnx DL4ABB
New: Support for FTdx1200
New: Dx Entity column added in the dx-spot tables
New: Open unlimited number of band maps: Menu-->Window-->New Band Map
New: Better CW window
Here is the latest version from the Mac App Store:
https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
Download the latest version here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:
http://dl2rum.de/RUMlogNG/docs/en/
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
Advanced search options
Areas currently located in the gray line
K7RAN
Posts: 42 Joined: Fri 14. Jun 2013, 11:43
Unread post
by K7RAN » Wed 20. May 2015, 14:20
Wow, exciting upgrade, Tom! Thank you!
Randy K7RAN
ik2eae
Posts: 37 Joined: Sat 25. Apr 2015, 06:38
Unread post
by ik2eae » Sat 23. May 2015, 14:28
Good job with new feature, I suggest you to use a shortcut to access to search window
Unread post
by DL2RUM » Thu 28. May 2015, 23:18
Unread post
by DL2RUM » Sat 11. Jul 2015, 08:52
Version 1.2.5 is now ready for download and it is already in the Mac App Store. The latest version in the store was 1.2.3. Here are the latest changes:
1.2.4 13-June-2015
Fixed: CW window Info field are not any longer mirrored in the rst field - Tnx DH6YMC
Fixed: OS X notifications take eQSL and LoTW users now into consideration - Tnx NY4I
1.2.5 1-July-2015
Fixed: Printed QSL label shows correct rst now - Tnx OE1HXS
Fixed: QSO Search window will be updated after log changes - Tnx DK5LP
New: Support for FT-1000MP Mark-V - Tnx OE3ASA
New: qrz.com/HamQTH.com informationen can be shown now below the logging window
App Store:
Updated English manual:
Updated German manual:
pip
Posts: 11 Joined: Sun 20. Oct 2013, 07:49
Unread post
by pip » Sat 11. Jul 2015, 16:23
I still love rumlog, and rumlogng looks a lot better than the old version.
I do have a few issues you might consider for a next release of rumlogng:
- in the old rumlog Name and QTH would be filled in based on the last QSO with a station, I'd like to see that back. We're running a clubstation, so a lot of QSO's with the same stations...
- the eQLS upload reports "a timeout" while actually the upload was successful.
Unread post
by DL2RUM » Sat 11. Jul 2015, 21:37
I have seen the eQSL timeout problem last week for the first time. I have to check, why it popped up now.
To use the data from previous logged QSOs, go to the preferences under the Databases tab and set the options which cover your needs.
Prev. QSO Data.tiff (27.66 KiB) Viewed 11007 times
K8AJS
Posts: 52 Joined: Mon 26. Oct 2009, 03:08
Unread post
by K8AJS » Tue 14. Jul 2015, 12:53
DL2RUM wrote: I have seen the eQSL timeout problem last week for the first time. I have to check, why it popped up now.
I'm having a problem with LotW In and eQSL in. LotW Out and eQSL Out are working fine, but when I try the In functions I have no success.
In eQSL In, I click the button for "Read data from eQSL" and immediately get a red "Error" indication.
In LotW In, I click the button for "Read data from ARRL", it displays "Connecting..." for 30 seconds and then I get a red "The request timed out."
Ideas?
John K8AJS
bastinj@gmail.com
Unread post
by DL2RUM » Tue 14. Jul 2015, 13:50
Both functions are working very well in RUMlog normally, when the server side is okay. Do you have it had working before?
K8AJS
Unread post
by K8AJS » Tue 14. Jul 2015, 14:00
DL2RUM wrote: Both functions are working very well in RUMlog normally, when the server side is okay. Do you have it had working before?
No, I haven't had it working for download since I installed it. I've double-checked the logins and passwords, and in fact they should be correct, since the uploads work without a problem. For some reason, the downloads just don't work.
(Do you still have the log I sent you? The situation was the same there; perhaps you could check it to see if it works for you?)
John K8AJS
bastinj@gmail.com
