Using version 1.07. I entered a record by accident and went to delete it. RumlogNG deleted it but the record reappeared about a minute later. I deleted it (again) several times, each time it reappeared. I then took a new call and logged it and later when I went to exit the program the new logged call was not saved.
When I started the program again I had to enter the new logged call again, this time it took it. The deleted call did not return.
Jerry AC4BT
Can not correctly delete a log entry
Re: Can not correctly delete a log entry
I have experienced the same problem once before, but I was not able to reproduce it. The problem was a locked database, due to an aborted database operation maybe.
When it happens again, please check the Console. There must be Log entries concerning the database!
Thanks Tom. I'll keep an eye on it. Otherwise, I really like the new RumlogNG application. It's fast and responsive. I especially like the fact that I can use the Keyboard to key CW on my KNWD TS590S. Thanks for putting the support in for that.
Jerry AC4BT
Jerry AC4BT
I have seen this before when deleting made up qso's for testing. Will look at console next time
Tnx Billy NN5EE
Tnx Billy NN5EE
I have seen these "zombie" QSO's also.
I find that if I delete them and then quit the program and restart they stay gone.
Rick
Rick
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
