K3 CAT
NF4L
K3 CAT
Unread post by NF4L »
I can't get CAT working. The settings are the same as I used in classic RUMLog (38400,1,N) which still works fine. I have tried re-starting NG and cycling the rig and Menu>Transceiver>Reset CAT.
I have a K3, P3 and SteppIR antenna. I have not tried fldigi yet.
73, Mike NF4L
73, Mike NF4L
Re: K3 CAT
Can you post a screen shot of your settings please?
NF4L
Re: K3 CAT
CAT settings/K3
CAT settings/K3
DL2RUM wrote:Can you post a screen shot of your settings please?
73, Mike NF4L
Re: K3 CAT
You have to select your Elecraft model from the 'Type' popup menu. Use the '-Ctrl' selection for a full control window.
NF4L
Re: K3 CAT
DL2RUM wrote:You have to select your Elecraft model from the 'Type' popup menu. Use the '-Ctrl' selection for a full control window.
The popup says "Item 1" "Item 2" "Item 3"
After selecting an "Item", the closing and reopening preferences, the popup is correctly populated.
73, Mike NF4L
Re: K3 CAT
Sounds buggy. Select another manufacturer, reselect the Elecraft and try again.
K3DCW
Re: K3 CAT
Unread post by K3DCW »
That's strange, Mike.
Same setup here: K3/P3 and there's no issue.
Which version of NG are you using?
Dave
Dave
K3DCW
"Hamming it up on macOS"
NF4L
Re: K3 CAT
DL2RUM wrote:Sounds buggy. Select another manufacturer, reselect the Elecraft and try again.
Just a bit. :D Isn't Cocoa fun?
After selecting an "Item", then closing and reopening preferences, the popup is correctly populated.
73, Mike NF4L
