I believe the n0nbh site may have recently changed its format for Solar Terrestrial data feeds. I notice now the data feeds in the Rumlog window all have old data. i.e. one screen (Orange) has a date of June 14th (today is June 24th) while the (Gold) screen has a date of May 25th... It is very bizarre since almost every different screen color (Orange, Gold, Green, Red, White Light, etc.) has a different date listed for the feed.
Is anyone else experiencing this same condition with the Solar Terrestrial Data window (Picture or HF)?
I am not using a proxy and all other data communications work as expected... LoTW uploads, DX Cluster Telnet, QRZ lookups, etc all work as they should... In fact the VHF solar data feeds do work and are current data feeds, it is just the HF solar data that shows old data. Not a big deal if it does not work, I just wanted to see if anyone else was also having the same issue.
Thanks for the quick reply Tom... I appreciate your assistance with checking on this for me.
Sorry for jumping in late, but I just checked this out on my machine and at first it wouldn't show at all, then I closed the window and told it to open again and the update data was there; for whatever that is worth.
I'm also finding the solar terrestrial data window no longer works. Closing the window & re-opening it doesn't help. just a blank window with a question mark top centre.
It's always worked fine for years & I assumed there was some configuration problem on my side, but it appears others are seeing it also.
Also maybe worth noting is that it works fine on RUMped, it's RUMlog that seems to no longer work for me.
