Hallo! I have one question. I haven't possibility for use the command into the menù "Command Cluster". They are all grey, I think disability, but I have regular connection with the cluster (via telnet with K9USA).
Why...?
I send a picture's menù
Thanks a lot! Dan.
Schermata 2014-06-15 alle 20.03.31.png (39.97 KiB) Viewed 9248 times
Yes...it's only function operative, but the other not run.
For example "announce the last QSO" it's disability, Macro1..2..3..ecc. it's disability...where is the problem...?
I have only two macro edited, but i can't see the name and the macro not run...
I'm interested the function the first command, for announce the last qso logged, but this function not run also...
Schermata 2014-06-15 alle 20.03.31.png (39.97 KiB) Viewed 9237 times
To use the macros you need an open telnet connection. To announce a logged QSO you have to log a QSO first. After that the menu item will become active. Have a look into the terminal window. Do you see your defined macros?
I solved the problem
The menus are disabled in the telnet window that opens automatically when the program starts.
If I open a new telnet window, the commands work regular.
Thank you, Dan.
Schermata 2014-06-18 alle 09.03.29.png (41.03 KiB) Viewed 9223 times
