Can't connect yaesu ft 450 at CAT Control
Hello everybody!!!! Anyone have the settings for Yaesu ft 45o at . i Can't connect the cat controll,any idea
Re: Can't connect yaesu ft 450 at CAT Control
For my rig FT450D I have set the following in the preferences:
baud 38,400
bit 8
parity none
stopbits 1
Xon yes
set RTS line on
Make sure you select the serial port from the drop-down menu that is connected to your rig. I use a generic serial to USB adapter with a mini gender changer at the back of the rig.
Hopefully you have already figured this out!
KB3SJS
baud 38,400
bit 8
parity none
stopbits 1
Xon yes
set RTS line on
KB3SJS
