I'm very interested in the US Counties, but some bugs or missing counties were found. The list of the counties is not the same that appears in QRZ.COM (for example ST. for Saint, and uppercase/lowercase . That comment is because to calculate the number of counties uppercase/lowercase are sensitive, giving a wrong number.
Take note that AZ,YAVAPAI county are missing.
Other point is if is possible to implement the opcion to save as .TXT or copy to the clipboard?
I agree, this is a problem. There is no official county list to use. From one station you may find different spellings for the same County in qrz.com and in LoTW.
Please see it as operating aid, not as a tool to apply for the award. I will add the missing County.
BTW, you can edit the County list by yourself using a SQLite database tool. (MesaSQLite or SQLiteManager) The County table is within the IOTA.rsd database.
What do you want to export as text? Your worked/confirmed County table?
The second time I used PSK31, the interface flipped back and forth between PSK and RTTY at a rate of about once per second. I closed the interface window and got a message "An exception of class NilObjectException was not handled. The application must shut down.". Since re-starting RUMLog, it has performed perfectly.
In my 2nd QTH (not main station) tried to install RUMLog 5.0.8 on MACBook Pro, MAC OS X 10.6.8 connected to ICOM-706 MK IIG by microHAM USB Interface II (CAT and Key). RUMrouter can't open microHAM port. Is this a supported configuration or am I missing setup steps, software, or hardware?
