Today I set up label printing.Using the QSL Label Editor, For Paper and Label I selected Avery 5160, and from the other template setting, I selected 2 line on Avery 5160.
The border and spacing settings look OK, and the graphic looks correct.
The labels print too low on the label stock. There is approximately 0.25 inch above the first line, and the 'Thanks for the QSO' line is right on the division between rows. The equipment line is below that. Also, the "TO Radio:" line does not have 'via NF4L'. The option is checked. I do to see a place to edit that line to put my call in it.
I really would like to print 4 lines, but when I load that template, make changes, and save it, Rumlog crashes, then restarts.
If there is a manager, can RumLog print an address label for him as part to the QSL printing? If not, I'd like to request that be added.
Are there QSO selection routines I've missed? What I see is across the bottom of the log.
I'd like for instance, to select QSO's between certain dates where I have sent a card, but not received one. One suggestion is for a dialog for building a SQL query, where the user selects from date pickers and checkboxes for other criteria, example band, mode.
I attached a screen shot of my Windows log program selection dialog.
Thanks for the great program!
73, Mike NF4L
Label printing
Re: Label printing
I was able to finally position the printing so that I can get 3 qso's on a label. It still starts about 0.25 inch from the top.
The other comments and questions remain.
Mike
Mike
73, Mike NF4L
Re: Label printing
Make sure, in the OS-X printer setting dialog are all borders set to zero! It's a good practice to create a new paper template. See the User's Manual page 68!
You can select multiple QSOs in the log table, even when the search criteria are used. When you select now Menu-->QSL-Print QSL only the selected QSLs will be printed. For more complex search routines you can use the search window. After you made your selections, use Menu-->QSL-->Send Paper QSL agn.
When the "Print 'QSL via'" option is set, the manager from the log entry will be printed. (To Radio: 9X0TL via DL2RUM)
Re: Label printing
Thanks Tom.
If by "OS-X printer setting dialog" you mean a dialog like the bottom one on p. 68, I cannot find one like that.
I understand the one can select multiple QSO'. I had not discovered the Search window. Please consider adding QLS sent and received status.
Ahhh. OK. I thought that the "QSL via" line was from the user. I didn't realize that in the sample label "DL2RUM was the manager". So is there a way to print an address label for a manager? (So far no managers have shown up).
A couple more little difficulties I'm having.
I'm not sure what to call it(auxiliary spots?), it's the little window just to the left of the "Logging Mode" label. It has a copy of spots in it. When a new spot comes in and the window scrolls up, it also scrolls horizontally so that only the last few characters of the call sign are shown. The horizontal scroll bar doesn't move until you click on it.
When I double-click on a spot, is there a way to turn off the pop-up screen(s)?
Using the color editor, I can't get the spot window to have alternating row color.
Is it possible to drag the columns in the spot window to a different place?
In the spot window, I am unable to make the Band col narrower. When the mouse is on the border between Band and cq, the pointer only has a right arrow, not bi-directional.
OK, I'll stop. My thanks for the time and effort you've put into this project.
73, Mike
When I select Digi>Show controls, I get both the RumLog RTTY screen and the CocoaModem screen. I want only the RumLog screen. Is there a setting for that?
73, Mike
Re: Label printing
In the Print dialog is a popup "Paper Size", there is an entry for "Managing Custom Sizes..." Then you can create a new template for your sheet size and set all borders to 0If by "OS-X printer setting dialog" you mean a dialog like the bottom one on p. 68, I cannot find one like that.
???I had not discovered the Search window. Please consider adding QLS sent and received status.
See the QSL menu and the User's Manual pg. 24So is there a way to print an address label for a manager?
No!When I double-click on a spot, is there a way to turn off the pop-up screen(s)?
For the dx-spots is a text- and a table view available. Only the tableview shows alternating row colors.Using the color editor, I can't get the spot window to have alternating row color.
No.Is it possible to drag the columns in the spot window to a different place?
There is an invisible line between. Temporally expand the rows, when only one drag direction is allowed.In the spot window, I am unable to make the Band col narrower. When the mouse is on the border between Band and cq, the pointer only has a right arrow, not bi-directional.
You can configure cocoaModem to show the Lite Interface. You can hide all windows now.When I select Digi>Show controls, I get both the RumLog RTTY screen and the CocoaModem screen. I want only the RumLog screen. Is there a setting for that?
Re: Label printing
Thanks once again, Thomas!
The more I use RumLog the more power I discover is already there!
73 & gud DX!
Mike NF4L
I still cannot find the Print dialog. How do I gain access to it?In the Print dialog is a popup "Paper Size", there is an entry for "Managing Custom Sizes..." Then you can create a new template for your sheet size and set all borders to 0
Change the selection in the Search window so that QSL received and QSL sent could both be used in the same query. I could then find QSO's where a QSL has been sent, but not received. This would be very useful for finding QSOs to resend a card to. I know I can select QSLs not sent, and then manually remove them from the result set, but I believe my suggestion would simplify the process for the user.I had not discovered the Search window. Please consider adding QLS sent and received status.
How to switch from text to table?For the dx-spots is a text- and a table view available. Only the tableview shows alternating row colors.
73 & gud DX!
Mike NF4L
73, Mike NF4L
