I have not used RUMlog for paper QSL'ing before but just got a nice Bureau pack in and am looking to log the cards in and probably use GlobalQSL to respond.
In checking my log I find I have a bunch marked "R", probably ones I have responded to in other programs and am sure I can clear them out by doing a "dummy" "Paper QSL print".
However I also have a bunch of QSO's with an "I" status. I don't know where that came from and don't find it listed in the manual.
Any ideas?
Paper QSL Status
Paper QSL Status
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: Paper QSL Status
I have to update the manual.
'I' is an ADIF conform Enumeration and stands for 'Ignore' or 'Invalid' In RUMlog it is the same as '-' I guess, you got it during your initial log import.
Thanks Tom,
Looking closer all the "I"'s are from a single import of a contest log.
I think I will export them, delete and then re-import.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
You want to delete all QSOs with the 'I' in the QSL status?
Yes,
Done, since they aren't impacted when if I change their status to "R" if I get a card from them I guess I could have just left them alone but I did the export, delete and reimport after doing a search and replace on the exported file all are now set to "-".
But, like I said it was probably a waste of time.
Oh well, no harm done.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
To delete all QSOs with status 'I' I would use a SQLite database tool and execute the following command:
Or with 'on board' tools:
Set the log table to show all QSOs
Mouse click on the QSL header to sort the log by QSL status
Select all desired QSOs
Menu-->QSO-->Delete QSO
Both ways are more effective.
delete from logbook where qsl="I"Set the log table to show all QSOs
I didn't want to just delete them I wanted to change their status since I didn't understand the "I" status.
So, I selected them all, exported them then deleted them as you suggest. Then I used TextEdit to Find and Replace the "I" status to "-" then reimported the QSO's
Now that I know what the "I" status is it was a waste of time but, like I said, no harm done.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
