Table View Colors
K6LE
Table View Colors
Unread post by K6LE »
I have noticed that when an unconfirmed spot (Entity, Freq or Mode) shows up in Text View it's displayed in the normal Amber color. However when that same spot is displayed in Table View it's in Yellow.
Not a problem now that I am used to it but seems a little strange.
BTW, Text and Table view are working out great for me especially since RUMlog can now connect to more than one Node.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: Table View Colors
Well, that's right. The original colours looked not very well with my defaulted back ground colours. (Gray-blue theme) That's why I changed the colours slightly. I have to add an option to make these colours user selectable.
K6LE
Thanks for the quick response.
As I mentioned I it really isn't a problem, now that I am used to it, just a curiosity.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
w2nra
Unread post by w2nra »
K6LE wrote:I have noticed that when an unconfirmed spot (Entity, Freq or Mode) shows up in Text View it's displayed in the normal Amber color. However when that same spot is displayed in Table View it's in Yellow.
I get the same here only it is ver hard to see the yellow against the pea green background. You'd think that such an important need, unconfirmed on any band or mode DXCC entity, should command higher contrast color scheme.
73 Art W2NRA
In the next version you can adjust the colours for your needs. Send a PM if you want to try it out.
