RUMlog 5.2.5
Posted: Mon 5. Aug 2013, 15:14
Version 5.2 04-August-2013
Changes for tqsl V1.14
Download from the ARRL here: http://www.arrl.org/instructions Put a copy into your RUMlog folder!
See the RUMlog Preferences LoTW tab for further settings. You can pass now the password for signing your QSOs. Further, tqsl can send the signed file to ARRL. Make the appropriate selection in the popup menu.
ESM (Enter sends messages)
Press the small triangle in the CW Window to show the ESM controls. You can control CW via keyboard or pressing the buttons.
F1-F3: sends messages
Escape: cancel transmission
Cmd W: clear fields (wipe)
Ctrl L: save QSO to log
Only the application file itself was changed.
Download the application only: http://dl2rum.de/rumsoft/RUMlogApp.zip
History: http://dl2rum.de/rumsoft/rumlognews.html
- Simple ESM interface for CW added if you want to run a pile up on the fly - see below
- 6-band and 10-band info for DXCC Challenge added (DXCC List Window)
- K7PT database will be downloaded now every 4 hours, helpful if you are running RUMlog 24/7
- WWV and Announcements are shown now in tabs beside the bands. Uncheck the options in Preferences—>DX-Cluster to hide the separate windows
- Additions made to use the advantages in tqsl V1.14 - see below
- Clublog Interface rewritten, there were few heavy bugs. When you are using the "Real Time Upload" option, you should delete your Log in Clublog and upload the full log again. (Menu—>Log—>Upload all QSOs to Clublog)
- All used modes in the Log are now selectable in the Search Window
- More AppleScript commands added
